Kitchen outlet problem
Received 0 Votes
I plugged in a intercom into a GFI outlet in the kitchen and after about 5 minutes it tripped the GFI. I tried this several times and it kept tripping the GFI. I then plugged in into an non GFI outlet and tripped again, however when I reset the GFI this time only half of my outlets work. I tried all the circuit breakers in the panel box and they are ok. and I reset the GFI and still no power to 3 outlets. Clockwise: I have a regular outlet not working, GFI working, regular outlet not working (one I plugged intercom into), next regular outlet is working. followed by one not working and finally a gfi outlet that is working..
Any thoughts on trouble shooting??
Thanks in advance..
Thanks in advance..
Received 0 Votes
If you don't have another GFCI, then look for an open circuit. It would help if you knew if you had any power to any pf these receptacles. Use a plug in type tester or a two wire tester and test between the hot and ground, the hot and the neutral, and the neutral and ground.
Received 0 Votes
Blown GFI
Start with the first GFI rec you used.
With everything disconnected. Shut off the breaker. Remove GFI rec, Splice the ckt thru, Cap off wires. Turn the ckt on and see what you have.
If all work, shut off ckt. IDENTIFY feed wires, then reinstall new GFI rec--Line -load- as described.
