Broken Bx Cable
Old 03-16-07, 10:53 AM
Unhappy Broken Bx Cable
i was wondering if anyone had a suggestion on how to repair a BX cable I cut into while installing in-wall speakers. My saw cut into the metal and on grazed one of the wires. It did not cut the wire but I can see copper. To add a junction box seems a bit too much and if I can avoid it I would like to. Safetly. Anyway is there a sleeve that is sold? Or can a nice hunk of electrical tape do the trick? Thank you!
Old 03-16-07, 11:05 AM
Either install a junction box (probably two) or replace the cable. Those are your only code compliant and safe options.
Old 03-16-07, 11:09 AM
you need to repair that bx either a box or new cable its gonna be tough without making a big hole and is there enough slack is it at the end of the circut then u could eliminate it at the box before it.its a hazzard fix it corectly
Old 03-16-07, 12:52 PM
Received 42 Votes on 40 Posts
This really needs to be repaired correctly by replacement or addition of two j-boxes. An in-wall short to the spiral sheathing of old BX can cause that cable to glow red hot and catch fire.
