S fuse adaptors
Old 03-17-07, 06:40 PM
E
I am hesitant to consider pursuing this despite all the advice (from people I respect) strongly discouraging it, but the contact point supplying line current on one of my type S fuse adapters (the part of the adapter with which the tip of the Type S fuse makes contact) blew off when the fuse was screwed in (as a result of a (since corrected) direct short downstream in the circuit). I cannot fathom that the entire panel will need to replaced as a result of this. Adding a sub isn't really an option because the panel is flush mounted in the family room. Is there really no safe and effective way to remove the adapter (and of course, replace it with another)?
Old 03-17-07, 08:29 PM
L
Sorry.
You lost a slot. If you want it back.. Upgrade the panel.
Spend a dime and save a buck.
There is no real way to recapture that spot, By the time you try to.. the money,time and effort put into it. The job would be done.
I can't believe I even typed that.... Change out the panel.
Old 03-17-07, 11:22 PM
rdn2113's Avatar
lectriclee is correct. But just for fun, take a look at www.fuseone.com.
