Thermostat wire for heat pump
Old 03-23-07, 02:16 PM
Can standard thermostat wire and wire nuts be used for heat pump control cabling, or is something special required?
Old 03-23-07, 06:03 PM
kcxj's Avatar
Heat pumps require a few more wires. A standard condenser needs only four, but a heat pump needs atleast 7.
Old 03-23-07, 08:33 PM
I've got 7-conductor from the thermostat to the air handler, and 5 to the condensor. I already have it all hooked up. I was wondering about if the cable had to be watertight or use special wirenuts or anything, or if normal thermostat wire and electrical wirenuts were OK?
Old 03-23-07, 10:58 PM
Outside, use silicone filled ones. The cable is fine outside.
Old 03-24-07, 05:37 AM
Your normal thermostat wire and wirenuts are fine. Use at least 18 guage wire.
