Is 220V 230V 240V the same?
Old 03-23-07, 07:09 PM
I have a welder that the voltage is 230, sngle phase, 60 HZ. or 208, single phase, 60 HZ.
The power at the breaker box is 240, single phase, 60 HZ.
Can I use this welder? Will difference in voltage be a problem?
Thank you
Old 03-23-07, 07:36 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Yes. In different parts of the country, line voltages can vary as much as 10%, so 220 or 240 are within limit ranges of each other.
Old 03-23-07, 07:43 PM
Thanks for being so prompt. I guess I was hoping to hear what you said.
I guess I forgot all the question. There is a jumper inside the welder that can be set on 230V or 208V. Being that I have 240V, what about the jumpers?
Which one do I put it on or does it matter?
Thanks!
Old 03-23-07, 07:48 PM
nap's Avatar
nap
nap is offline
New Member
yes, you can use 240.
240 and 208 are nominal voltages for supply power. The voltages on a piece of equipment are the design voltage for the eqipment. There are tolerances allowed.
One reason certain voltages are listed is the fact that when you take that voltage and consider the allowed tolerances, the acceptable voltage can be any of several different systems. Hence your machine being able to utilize 208 or 240 volt systems.
as well, through the years, the nominal voltage has risen. Years ago, a typical resi supply would be 110/220. Then it went to 115/230 an now currently is 120/240.
So either your welder is old enough to been around when 230 volts was the nominal voltage or they did it to allow it to be used on different types of service supplies. In either case, you're safe.
put the jumper on the 240 volt setting.
Old 03-23-07, 07:53 PM
I hate to be a pest. The jumpers are only 208V and 230V, not 240. Thats why I asked which one or does it matter?
Thank you
Old 03-23-07, 08:06 PM
nap's Avatar
nap
nap is offline
New Member
sorry 'bout that.
put it on the 230 volt setting.
Old 03-23-07, 08:10 PM
Thank you Sir:
At least I dont have to return it!
Have a nice weekend!
Thank you very much!
Old 03-24-07, 12:02 PM
The 208V setting is for places with 3-phase. If you're operating this in a residential setting, you won't be using 208V.
