light switch box sticks out too far
Old 04-13-07, 09:35 PM
Question light switch box sticks out too far
I have one light switch that the box sticks out too far from the wall, leaving a gap between the switch cover plate and the wall. Is there anything out there I can buy to fill in this space and make it look finished?
I have seen some frames, but I'm not sure if this will work. It's hard to tell from the picture. (see link below)
Any other ideas?
http://www.marketexpo.com/invt/2139&bklist=icat,5,shop,shopbyproduct,22_switchplates,sp100_accessories#
Thanks.
Old 04-13-07, 10:22 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Replace the box with an old work box. If you have a SazAll you can carefully cut the nails on the stud side. You can also use a hack saw blade.
Old 04-14-07, 08:25 AM
HotxxxxxxxOKC's Avatar
That trim cover you posted will not fix your issue. That plate is if the cut out of the receptacle opening is to large.
Old 04-16-07, 06:28 AM
Metal or Plastic box?
If it is a plastic box, use a Dremel Tool with a small grinder tip to carefully grind away the edges of the box till they are flush with the wall surface.
This will also work with a metal box, although it will take a lot longer.
