Question about adding wiring/outlets.
Old 04-14-07, 07:43 AM
Hello,
I'm in the process of finishing our basement. Our entire basement (except for washer, dryer, and furnace) shares a 15A breaker with the dining room (don't ask me why, I didn't do it). I'd like to add a series of outlets on a different breaker, as the breaker is tripped if you run a couple things with the lights on. My garage is wired to a 50A breaker, but there is nothing out there. Can I wire these outlets in the basement to the garage breaker? TIA.
Old 04-14-07, 08:14 AM
HotxxxxxxxOKC's Avatar
You cannot have anything more then a 20amp breaker running normal 120v receptacles and lights.
Old 04-14-07, 10:54 AM
nap's Avatar
nap
nap is offline
New Member
Ya, that kind of freaked me too.
Your garage should only be fed with a 50 amp circuit if that circuit feeds a sub-panel. Does it?
Is the garage attached?
Do you have any breaker space in the panel? (in the house if more than one)
Old 04-14-07, 10:58 AM
You can use the 50 amp breaker to run ckt to the dinining room, if you run 6 guage wire, and fuse the wire just before the rec in a listed fuse box.
It would be cheeper to run 12 wire and buy a 20 amp breaker.
Old 04-14-07, 11:59 AM
Hi thanks for the quick replies,
'You cannot have anything more then a 20amp breaker running normal 120v receptacles and lights.'
OK, so I feel pretty stupid not knowing that.
The garage is not attached and it does have it's own sub panel.
There is one space left for a breaker in the main panel, so I will definitely add a 20A and go from there. Thanks alot!
Old 04-14-07, 12:16 PM
nap's Avatar
nap
nap is offline
New Member
sounds like the best arrangement.
stop back when you have more questions. we know you will some.
but we are happy to assist where we can. good luck.
Old 04-14-07, 01:46 PM
"OK, so I feel pretty stupid not knowing that."
Never feel stupid about not knowing something. Stupid is reserved for those incapable or unwilling to ask.
Old 04-14-07, 02:18 PM
nap's Avatar
nap
nap is offline
New Member
I second that emotion.
Some of us here do this for a living and many of the things we know to be true are just not common knowledge.
ignorance: the state of having no knowledge of the subject. It is correctable and is nothing to be ashamed of. We are all born nearly totally ignorant and spend the rest of our lives trying to correct it. It is when a person is alerted to their ignorance and fails to make a correction is when shame comes into play.
