New 220V Garage Circuit...GFCI??
Old 04-20-07, 09:41 PM
T
I am adding a new 220V garage circuit for the purpose of running a welder and any future tools (not at the same time). The welder current draw is rated at 22amps max.
I am running a new circuit and I want as much future flexibility as possible. I only need a 10/2 run on a double pole 30amp breaker, but will run 10/3 for flexibility.
Since this is a general purpose garage outlet, how do I add GFCI to a 220V circuit most economically or do I even need it at all? I didn't find any GFCI L6-30 outlets, there were some double pole 60amp breakers (didn't find double 30amp) but they were $$$.
Also, this is not really necessary and I don't think there is a proper way but is there a way to leverage a 10/3 circuit for both 220V and 110V outlets?
Old 04-20-07, 09:50 PM
B
It is not required , nor is it even a good idea . The GFCI would trip the moment you struck an arc.
for 120/240 you need three wires, two hots and a neutral. And of course your ground. If you do run 10/3 then you could change to this config later in time.
However you can not have any duplex receptacles on this circuit. Run your 10/2 on a 30 amp for your welder . Run a seperate circuit for your outlets and protect them with a proper breaker.
Old 04-20-07, 11:36 PM
T
Ah. I'm relieved that I don't need to worry about the GFCI.
Thanks.
