230 circuit
Old 04-22-07, 07:39 PM
230 circuit
Is it acceptable to use 2 separate 15 amp circuit breakers rather than the
usual double breaker which is 30 amp to tie a 230 circuit into the breaker box?
Old 04-22-07, 08:21 PM
nap's Avatar
nap
nap is offline
New Member
2 15 amp breakers do not give you a 30 amo circuit. That gives you two poles at 15 amps.
if you wqant a 30 amp circuit, you have to use a 30 amp breaker
if the 15 amo breaker were placed correctly AND they were tied together, that would give you 15 amps at 240 volts but that's it.
Old 04-23-07, 04:37 AM
Why don't you tell us what you are trying to do. We can then provide better advice.
Old 04-23-07, 07:37 PM
You need a 2-pole 30A breaker for a 30A 240V circuit.
