Another subpanel question
Old 04-25-07, 11:06 PM
K
Hi all,
I have done a search and read through countless subpanel threads, which made me want to hire an electrician to do this, but I'd really prefer to do it myself.
My house has a new 200-amp main panel, with the main electrical loads being a 240v spa and an electric oven. I have a small detached rear house/shop (~300sf) that I am remodeling, and would like to rewire it properly. Suffice it to say that it needs to be completely rewired. It currently has 3/4" non-metallic conduit running from the main panel to the small house, about a 50-foot run.
The space will be used as an office/guest bedroom/laundry. What I would like to do is install a subpanel, to supply power to a 240v wall ac/heating unit (20 amps), a 120v washing machine, a gas dryer (also 120v), and about 8 other receptacles (for anything from a computer to a plasma TV). I will have 2 ceiling fans (with lights) and a track light on one circuit, the washer and dryer each on a circuit, a separate 240v circuit for the ac, and 2 circuits for the various receptacles. 6 breakers in total.
From what I've seen, I should be looking at a 60A-100A subpanel, running 3 6-gauge wires and a 10-gauge ground, with an 8' grounding rod.
Is that correct? Are there any other considerations I need to be aware of?
Will those wires fit through the existing 3/4" conduit, or do I need to dig up my recently-landcaped yard to run new conduit?
Is this something that I should be able to tackle myself, or should I leave it to the pros? Considering the 200A panel upgrade set me back over $2000, I'd prefer to do it myself, but I want to do it right.
Old 04-26-07, 03:46 AM
A 60 amp panel would do, but a 100 amp would give you room for expansion.
The 3/4 is too small either way, so there goes the lawn, but if you are carefull in three weeks you will not be able to tell.
Three number 2 copper with a number 6 ground in a 1 1/4 pvc conduit would work for a 100 amp panel. Three number 6 copper with a number 10 ground for 60 amps.
You can leave the existing pvc for phone and CATV.
BTW that was a great price for the service.
Old 04-26-07, 10:55 AM
I
Received 43 Votes on 41 Posts
A 60A subpanel will work with your existing conduit: (3) #6 + (1) #10 does fit in a 3/4" PVC conduit -- it's a 35% fill and code allows up to 40%. I'm not saying it'll be an easy pull, but with a lot of cable lube and careful pulling you should be okay.
From the loads you described, I think a 60A panel should be plenty adequate for your needs.
You seem to have it straight. Just remember to keep the grounds and neutrals separate in the subpanel. If your subpanel has more than 6 breakers, you need a main breaker in the subpanel. Some inspectors will require a main if the panel _can_ have more than 6 breakers, even if you only have a few installed. I would recommend a main breaker in the sub anyway.
Old 04-26-07, 02:41 PM
K
Thanks for the input! I'm going down to pick up a 100A GE subpanel w/main breaker at Lowes right now. Glad to hear that the wires will fit in the 3/4" conduit - I'd rather have the frustration of pulling the wires than digging up the yard.
Old 04-28-07, 10:38 PM
Its a feeder, #4 would work for 100amp. #2 would be 125amp.
Old 04-29-07, 08:52 AM
HotxxxxxxxOKC's Avatar
kellyandjulie,
If you read up a few posts, you will see that if you are running a 100amp sub, the 3 #2 WG wire will not fit in the 3/4" conduit you already have.
You can get a 100amp sub and use a 60amp breaker with the 3 #6 and #10 ground and be okay.
Old 04-29-07, 07:22 PM
K
Thanks - yeah, I've got a 60A main breaker for the new panel, and will run 3x 6-gauge and 1x 10-gauge ground.
What's the best way to fish the wires through the conduit? One at a time, or all at once? If all at once, what's the most effective way to do it?
Old 04-29-07, 07:53 PM
R
Use the old wires to pull the new wires, or run a string through and then use it to pull the new wires. Use plenty of wire lubricant. Use only wire lubricant, do not use anything else.
Old 05-01-07, 12:23 PM
K
So is it generally easier to pull them one at a time or all at once?
Old 05-01-07, 12:24 PM
R
All at once.
