Replacing ceiling fan with light ficture
Received 0 Votes
I removed the ceiling fan from ceiling to find there are 2 black wires and two white wires coming from the outlet box in the ceiling. The light ficture I have has 2 white, 2black and 1 green. When attempting to connect all whites to whites and blacks to black I trip the breaker. I purchased a tester to try to find + and - It tells me to place the black tester wire on a grounded screw and the red on a wire. I am getting no light, though I have wired the fixture a few ways that lights came off but would not turn on or off via switch.
Received 0 Votes
are you sure of the wiring of the orginal fixture?
sometimes people feel a bit stupid for not keeping track of things, and as a result do not tell us all of the information we need right away.
I have done most of the stupid mistakes that can be made, and seen most of the rest.. lol
You say you have tried to wire the fixtures a few different ways, do you know which way it was wired origanally? what have you tried and did not work?
Sounds to me like a simple switch loop.
Using your tester, find the black lead and white lead combination that activates the tester. Connect this white lead to the white leads of the lamp fixture. Connect the black lead that activated the tester to the remaining white lead in the box and stuff it into the box. Connect the remaining black lead from the box to the black leads of the lamp fixture.
Received 0 Votes
"I thought we where talking about a bathroom exhaust vent fan, I had just read that thread"
the requirement to have a bath exhaust vent is not in the electrical code.
when one is required, what circuit it needs to be on, is.
Received 0 Votes
There are some places in the US where the BUILDING code requires a vent fan in a bathroom that has no windows. However it is the building code, not the electrical code that requires the vent.
In this case I too suspect a switch loop. If we are told the wiring at the switch we can certainly figure this out.
