3/4 fmc from ceiling
Old 05-15-07, 12:21 AM
What is the proper way to bring the 3/4 fmc thru the ceiling to a J box.? J-Box will be mounted externally.
Is it ok to connect to the box directly from behind so you would not even see the conduit?
Also can I pull 3 - #6 and 2 - #12 thru 3/4 fmc?
Thanks.
Old 05-15-07, 08:21 AM
Yes. Just use the proper FMC x thread fitting to mate with the j-box.
Yes, but that is an unusual configuration of wiring. Could you explain what each is for? Do you have a ground wire?
Old 05-15-07, 12:03 PM
Thanks. I am not at the site now, I was going based on memory, I better look again.
