GFI 220 Breaker
Old 05-21-07, 07:28 AM
C
GFI 220 Breaker
I am installing a lawn pump. Pump instructions say to use a 15Amp GFI breaker. The pump is 220 volts. I can't seem to find a 15A 220 GFI double breaker. Any ideas?
Old 05-21-07, 07:32 AM
R
Stop trying to find one at the big box stores. Go to an electrical supply store.
Old 05-21-07, 07:38 AM
C
I just called my local electrical supply and they said they did not have anything like that. So I posted this on the forum to see if anybody had some advice.
Old 05-21-07, 07:45 AM
What's the make and model of your panel?
P.S. Unless your panel is long obsolete, they would certainly have one. Maybe you had a miscommunication?
Old 05-21-07, 08:10 AM
C
It is a GE 12MB12R Mod. 1 outdoor enclosure. The supplier I called said they had a 20 double but could not get or did not have 15 double.
Old 05-21-07, 08:40 AM
C
I am still thinking about this. I am going to use 12/3 UF underground to the pump. The pump will not be in the water. I will have 2 hots, a neutral and a separate ground running from the pump/motor to the panel. Is there any real reason I should even need to use a GFI?
Old 05-21-07, 08:49 AM
Run the #12 wire and use the 20A GFCI breaker, if that's all you can get. But yes, you need the GFCI protection.
Old 05-21-07, 08:58 AM
R
Why are you running a neutral?
Old 05-21-07, 10:09 AM
C
Why not? If I use 12/3 I have the completely separate ground. Plus that is what the pump instructions say to use.
Old 05-21-07, 10:46 AM
R
You have (and need) a ground regardless of whether you use 12-2 or 12-3.
12-3 will give you one extra conductor that you will pay dearly for and never use.
Old 05-21-07, 12:50 PM
The pump says to use 12/3? Or does it say to supply it with a neutral?
12/3 MC or NM cable (Romex) doesn't count the ground wire. (has 4 wires)
12/3 SO cord (or similar) does count the ground. (has 3 wires)
Is there anything at this 240V pump that requires only 120V?
Old 05-21-07, 03:14 PM
C
The pump instructions say to hook up 2 hots, the neutral, and then the ground wire to the case. That is why I was planning to use 12/3. I know it will cost more but I want to make sure everything is safe.
Old 05-21-07, 05:46 PM
If the pump says to land a neutral, than you do need the 12/3 with 4-wires. Since you are running #12, just use a 20A 2-pole GFCI breaker if that's what you can find.
Old 05-21-07, 08:24 PM
R
If you need the neutral then you need a 120/240 volt circuit, not a plain 240 volt circuit.
It's important that you use the proper terminology so that you get the right information.
Old 05-22-07, 06:20 AM
C
Post
The pump only draws 8.4 amps according to the literature and the specs call for a 15 amp breaker. I don't think it would be safe to use a 20 amp.
Old 05-22-07, 06:24 AM
R
If you can't find a 15 amp GFCI then install a fused disconnect and use 15 amp fuses, fed with the 20 amp breaker.
Old 05-22-07, 06:55 AM
pcboss's Avatar
Received 71 Votes on 61 Posts
You didn't say what type of GE breakers your panels uses but GE does show a 2 pole 15 amp GFI breaker.
http://www.geindustrial.com/cwc/Dispatcher?REQUEST=PRODUCTS&pnlid=3&famid=8&catid=36&id=cb-qgfci
Perhaps you could use the where to buy button to locate someone that does have one.
Old 05-22-07, 07:05 AM
C
Breakers that can be used on my panel: THQP, THHQP, THQL, THHQL.
Thank you for that link, just what I was looking for but couldn't find it.
Old 05-22-07, 07:32 AM
C
Smile
I found it!! THQL2115GF1 from GE. List price $282.00.
I already found one on EBay and several other sources.
Thank you pcboss for that link, exactly what I did not find on my own.
