Drop Box Wiring
Old 05-22-07, 10:01 AM
Drop Box Wiring
Could you give me the details on how to wire a 220VAC to 110VAC single phase drop box?
Old 05-22-07, 10:26 AM
pcboss's Avatar
If the box only supplies 110 volt you cannot get a 220 circuit from it. Most of the 110 volt services I have seen were less than 60 amps, sometimes 30. You may not have enough power available to run that load.
Sounds like it might be time for an upgrade to a standard 120/240 volt service.
Old 05-22-07, 11:05 AM
Drop Box Wiring
I do not believe I was clear about what I needed. I have a 220VAC line that was used for and electric stove. We no longer have an electric stove and I would like to convert the 220VAC into 110VAC. Could you give me the wiring info I need to do this?
Old 05-22-07, 11:35 AM
Unless you tell us what wires are presently there we can't help you. The bottom line is, you may or may not be able to do this.
Old 05-22-07, 12:03 PM
Drop Box Wiring
The box has 2 wires and an aluminum "braid". The 2 wires went to the circuit breaker box to a ganged breaker. The braid goes to the bus bar neutral.
Old 05-22-07, 12:33 PM
Replace the wire.
Old 05-22-07, 02:56 PM
Now the bottom line is that you cannot safely do this. There are many ways to get what you want, but your existing stove wiring won't help you get there.
Old 05-22-07, 06:16 PM
You need to change the breaker and the receptacle. That stove wire won't fit the smaller breaker or the receptacle. Replace the wire.
