green wire hanging from dryer receptacle
Old 05-26-07, 01:02 PM
Question green wire hanging from dryer receptacle
moved my electric dryer to clean the exhaust hose...that was easy enough but i noticed a long green wire hanging from the receptacle. the wire is exposed at the end as if it is supposed to connect to something??? am i supposed to do something with this?
Old 05-26-07, 01:15 PM
The green wire is a ground wire. Is this a four wire or a three wire installation?
Old 05-26-07, 01:26 PM
i was afraid you were going to ask a question...
the plug has only 3 prongs...
Old 05-26-07, 02:25 PM
Turn off the receptacle's circuit breaker and remove it from the wall. You can leave the wires connected to it, though. How many wires are in the cable that enters the box behind the receptacle?
Old 05-26-07, 03:46 PM
Sounds like someone tried to ground the dryer to the box with a separate ground wire. If the three wire plug is connected properly you do not need this extra wire.
There should not be any individual wires sticking out any receptacles boxes.
Old 05-26-07, 06:14 PM
Red face
thanks for the advice. i know this is all so very simple to do...but i think i may have to call in the local reinforcements for a look at this one...i am obviously very electrically challenged...
thanks again.
