service entrance cable
Old 05-29-07, 06:31 PM
I recently purchased a 2 family home for investment. I found that the main electrical wire was in very bad shape. The cable from the pole to the house is fine, but from the connection to the house the insulation around the cable is completely off in certain area's. I guess it had to due with the previous owner upgraded from a 100 amp to a 200 amp panel. I hired an electrician a friend recommended that is suppose to be lic. and insur. So now that I brought you up to speed my question is in the state of PA Wilkes barre -Scraton area is it allowed for the electrician to run service entrance cable along the side of the house and goes into the basement. The cable is not buried turns into the house before it reaches the ground. I thought it should be in pipe but he insisted that it was allowed by code and it did not have to be in pipe. Any help would be great.
Old 05-30-07, 06:17 AM
Check with your utility company, or local building dept.
In some places conduit is required if the conductors are within a certain distance from a driveway or walkway.
