Switch loop question
Old 06-02-07, 10:26 AM
I'm connecting a new light fixture to a switch loop and I just wanted to make sure that I wired it in an acceptable manner.
Should I wire the incoming hot wire to the black or the white wire that leads to the switch (single-pole)?
I'm assuming that if I wire the hot to the black wire going to the switch, then I need to wrap the white coming back from the switch with black electrical tape so that anyone after me knows that it is a hot wire.
On the other hand, if I wire the hot to the white wire going to the switch, then I need to wrap the white wire on both ends with black electrical tape so that it is properly labeled as hot.
Is one of these considered more standard than the other?
Thanks in advance!
Old 06-02-07, 01:15 PM
Received 1 Upvote on 1 Post
The black hot wire in the junction box goes to the WHITE wire to the switch, AND you should recolor this wire at both locations.
Old 06-02-07, 06:03 PM
Received 515 Upvotes on 420 Posts
The power wire TO the switch must be the white wire. That way the fixture has a black and a white to connect it up, not two whites. Recolour the white white wire.
