Wiring a j-box for a double wall oven
Old 06-04-07, 10:30 AM
Q Brizzle's Avatar
Getting ready to install a GE double wall oven. My question is about the connection of the oven pigtail to the 8/3+g cable.
The instructions say to put the junction box ON the wall, and not IN the wall.
This is fine by me, but I was uncertain as to which box to use. I would think a 4x4x2 steel box with cover would work...then just use a cable clamp to secure both the in and out cable runs. The incoming power would be NM-B cable, and the outgoing (the pigtail to the oven) is armored cable (8/3 +g).
Does this sound reasonable, or is there a better alternative to surface mounting a j-box.
Thanks!
Old 06-04-07, 11:37 AM
The oven will hide the ugly J box, so it sounds fine to me.
I would put a double box in the wall so that the romex does not need to be exposed, then I would put a box extension on top of that. The box extension would be outside the wall and give you a place to enter the box with the whip from the oven.
Old 06-04-07, 06:53 PM
You could likely install the box in the wall and use a plate with a knockout on it, and a 90 degree box connector.
Old 06-05-07, 06:33 AM
Q Brizzle's Avatar
ooh, I like those ideas, thanks!
