15A GFCI receptacle on 20A circuit?
Old 06-14-07, 09:54 AM
G
I'm planning to install a 20A circuit with a GFCI recptable. I have a receptacle that's rated 15A, 20A flled thru. Is this type of receptacle appropriate for a 20A wire? If I use one 15A receptacle, do all receptacles on the circuit need to be 15A? I expect 2-3 receptacles on this circuit.
I guess my basic questions is: How do yoiu decided what type of receptacle to use on a particular circuit?
Thanks
Old 06-14-07, 10:01 AM
HotxxxxxxxOKC's Avatar
You have a common GFCI receptacle. You are using 12-2 wire?
Old 06-14-07, 10:53 AM
R
In the US you are allowed to use 15 amp receptacles on a 20 amp circuit, as long as there is more than one receptacle or it is a duplex receptacle that is used.
Old 06-14-07, 10:56 AM
I
Received 44 Votes on 42 Posts
In the US, 15A receptacles may be installed on 20A circuits. Typically, you would only install a 20A receptacle "T-slot" if you knew you had a large appliance or power tool that has a 20A cord.
Old 06-14-07, 11:00 AM
G
Thanks for all replies.
Yes, I'll be using 12-2 wire.
The receptacles are all duplex. Why can you not use 15A rec on 20A wire if there is only one 15A rec?
Old 06-14-07, 11:14 AM
I
Because the rule says so -- it's somewhat of a technicality. The rule says that all receptacles must match the circuit except that 15A are allowed on a 20A if more than one.
Old 06-14-07, 11:28 AM
His original post says he is going to have more receptacles on this circuit, thus making his 15amp GFCI permissable under NEC 210.21[b](3)
R
I do not know all the reasons for this.
I do know that generally speaking when you have a single receptacle (meaning a simplex receptacle) on a circuit, it is usually a dedicated circuit, such as for an air conditioner. As such, the circuit is supposed to be sized for the load.
I think the idea is that they don;t want you using an oversized circuit (a 20 amp circuit) when the device calls for a dedicated 15 amp circuit.
