how to verify 220V on my AC unit?
Old 06-19-07, 01:41 PM
Trying to verify that Im getting 220V to my outside A/C unit. I pulled the 2 large fuses out of the box that go to the 2 incoming 110V lines. Each one shows 110V when checked to ground. How do I check for 220V?
Thanks.
Old 06-19-07, 01:44 PM
Use your analog meter and measure between them.
Old 06-19-07, 02:26 PM
240v
I dont have an analog meter. I have 3 digital and 3 testers that have the little lights (neon). All 6 show same results. each line to ground I get 110V. When I put one lead on each 110V line I get nothing on the testers. I will buy an analog if I have to. I just want to make sure Im supposed to put one lead on each 110V line to read 220V
Old 06-19-07, 02:33 PM
If you have 110V between each leg and ground, then the only way you cannot have 220V between the legs would be if your breaker is installed very wrong.
Old 06-19-07, 02:38 PM
Just tell us real quick what breaker box brand name it is ??
IF that is " GE " box with very small breaker[s] it very easy to land in wrong spot due the breaker construction
the only way you get full 240 volts is you have to move breaker one way up or down to get both hot buss[es] landed on that breaker
even with neon light tester will work on 240 volt circuit it will lit up as well if properly hook up but the anlog meter is the best because if you are reading 0 volts between red / black wire then you know you landed in wrong spot in the breaker box.
Merci, Marc
P.S. if you have duplex breaker aka twinner breaker in either 3/4 or one inch size that automatically NEVER get 240 volts at all
Last edited by french277V; 06-19-07 at 02:39 PM. Reason: add about the twinner breaker
Old 06-19-07, 03:23 PM
Thanks.
Ok, found the problem. I have a bad spot where the breaker goes in the main panel of the house. I forgot my new bro-in-law is an electrician. I called him and he asked if I have a double pole-single breaker I looked and I dont, I have 2 breakers. Checked the breakers and one had nothing coming out. So moved it up one slot on panel and it was good.What do you know. My A/C unit came to life.
Thanks to all who helped.
Old 06-19-07, 07:01 PM
This 240V equipment is fed from two separate breakers? This needs to be replaced with a double-pole breaker.
Old 06-19-07, 07:20 PM
You must install a 240 volt breaker. Code (and common sense) requires this.
