What is the maximum wattage I can pull from a 100 amp sub
Old 06-23-07, 07:03 PM
R
The answer, assuming a 100 amp circuit breaker is used, is 100 amps * 240 volts, or 24,000 watts.
B
Thumbs up What is the maximum wattage I can pull from a 100 amp sub
panel with all 240v. aplliances? Thanks
Old 06-23-07, 07:07 PM
B
So these is no conversion for how many watts I can use
at 240 volts as opposed to 120 volts? I thought this was simple...?
Old 06-23-07, 07:10 PM
R
P = VI
Power equals voltage times current
Power equals volts times amps
Old 06-23-07, 07:14 PM
R
I said that in my first response. Which, due to a bug in the software running this site appears before your question.
B
So your sayin 24000 watts from a 100 amp sub at 240 v?
Old 06-23-07, 07:20 PM
B
Ahhhh Thanks much
Old 06-23-07, 07:48 PM
HotxxxxxxxOKC's Avatar
Please refrain from these "....................... ?????????????????????" posts before they get deleted.
Old 06-24-07, 10:07 AM
B
I just do that because I have nothing else to say
and the software won't let you post with no message...
Old 06-24-07, 11:23 AM
Put your message in the message block. Leave the title blank.
