Kitchen Light not working
Old 06-30-07, 04:20 PM
Hi,
My Kitchen (ceiling) light has 4 florescent tube lights. 2 Weeks back, the light died suddenly. Flipped the switch.. no light. Last weekend, I replaced the light switch (thinking it was bad), but still no luck. What else could be the problem?
Thanks
Nick
Old 06-30-07, 04:26 PM
Hi,
Thanks
Nick
Old 06-30-07, 04:28 PM
HotxxxxxxxOKC's Avatar
Sounds like the light ballast has gone out. You should check for power at the wiring with a volt tester.
Typically, you can replace the whole fixture cheaper then buying a ballast.
Old 06-30-07, 04:32 PM
Hi,
Thanks for the quick response.. how does the light ballast look like? I don't have a volt tester, any other alternative ways to check?
Thanks
Nick
Old 06-30-07, 04:36 PM
Ok, first look around the sides of the fixture. Is there a round cylinder (usually silver) looking thing that screws on? If there is, this is called the starter, not all newer lights have this. If it has this, I would replace it.
The ballast is within the fixture and resembles a black brick with a bunch of wires going to it. Before you go around poking in there, shut the breaker off. You can get a cheap volt tester at auto and big box stores.
Old 06-30-07, 04:55 PM
Have you tried changing the tubes. If that doesn't work then it could be a bad ballast.
If you really think you have a power problem then use a tester to verify if there is incoming power at the fixture.
Old 06-30-07, 05:09 PM
There is a post from this user in the electrical forum. This one should be moved or the other one needs to be merged into this one.
