Humming Doorbell Chime box
Old 07-03-07, 12:55 AM
Question Humming Doorbell Chime box
At 2:40 am I was awakened by a doorbell ring. I discovered a humming noise coming from the chime box. What is causing the humming and how do I stop/fix it. Thanks, Cando06
Old 07-03-07, 04:22 AM
My guess would be a problem with one of the bell switches at the doors, making light contact. There is no moving power in the doorbell system until a button is pushed(not quite true if you have lighted buttons). Also remove the cover and check for something loose in the solenoid mechanism.
Old 07-03-07, 07:02 AM
I agree. Probably a stuck doorbell button. Replace it. They're cheap.
Old 07-03-07, 10:37 AM
ray2047's Avatar
If it sticks long enough it may burn out the chime or transformer.
Also I have seen some chimes mounted with the transformer in a box behind the chime. It could be the humming of a transformer going bad in that case. Buttons though are first check as originally suggested.
