CAT5 for a basic Doorbell?
Received 0 Votes
I just moved into a new house and realized that the 2 doorbell buttons are wired with CAT5 wire down to the basement with nothing connected. Apparently the builder was thinking that I would want to install a phone/intercom system but I just want a basic doorbell. Is there any way to attach a regular doorbell transformer using CAT5? From there I could install wireless chime extenders. Thanks
Wires wire and plain old doorbells aren't particular about the wire. I wouldn't spend money for cat 5 but I've seen plenty of doorbells wired with no frills two pair wire. When I did it I usually used two wires together for each side just to increase the ampacity a bit.
Having seen a few chime coils melted due to stuck buttons or wiring shorts, I can say that I would rather have the coils melted than the wiring in the walls.
Some may say there is only a remote possibility of a problem but I would always make sure that the weakest link is not the wire, but a fuse, the transformer, or the chime itself.
I don't know the rated capacity in Amperes of Cat 5 at 16 VAC or whatever you're going to run but if you've got time to kill, since doorbells are historically wired with 16 or 18 AWG ...
Figure the cross-sectional area of 18 or 16 AWG wire and then figure out how many of the "cat 5" wires you will need to parallel to approximate that same cross-sectional area. I think "Cat 5" runs around 24 AWG.
In my own house I use 16 AWG for all doorbell circuits.
Otherwise you could also use a small relay or solid-state circuit in the basement and just run that miniscule amperage through the Cat 5.
