Mobile home circuit breakers upgrade
Old 07-10-07, 03:10 PM
Question Mobile home circuit breakers upgrade
We live in a new manufactured home and our parents are coming to stay in their motorhome in the yard. We are told we need a 30 amp breaker for the outdoor plugin for the motorhome to receive proper service. Are the breakers in the service panel in a manufactured house the same as a stick built and can we just replace a breaker going from a 20 amp to a 30 amp?????
Old 07-10-07, 03:26 PM
No. You need a 30 amp receptacle, and 30 amp wire. A 20 amp breaker will only have wire rated for 20 amps. The next question to ask your parents is, "Does the motor home need a 120 or 240 volt receptacle?"
Old 07-10-07, 03:27 PM
> as a stick built
Depends on the brand and model of the breaker panel. Usually manufactured homes use a common brand. What is the make and model?
No; this would create a substantial fire hazard. You would need to install a new 120V 30A circuit from a 30A single pole breaker in the panel to an outdoor RV receptacle using #10/2 copper wire.
Old 07-10-07, 05:52 PM
Who told you that you needed a 30A circuit? The ones who own the motorhome, or someone else? If someone else, are they familiar with that motorhome or are they guessing?
First, will they need a full 30A circuit? If this is temporary, you can get (and they might likely already have) a 30A-to-20A adapter and they can plug into any outdoor receptacle already there, though in addition to only having 20A available (might not run the air conditioner), there might also be other things in the circuit, further lowering what they can power.
If you install a 30A circuit, you'll need #10 wire.
