Generator questions?
Old 07-11-07, 08:34 PM
Unclediezel's Avatar
I will be installing a manual transfer panel for my portable generator. A few quick Q's, simply because I dont know......
#1...This will be a Seperate panel from my main load center. As for grounding, do I follow the guidelines for a Subpanel and isolate Neutral from ground.
#2.... Maybe kinda stupid , but I understand the function of the "Rocking Toggle, Finger type " thing that keeps the breakers from being on simultaneously. What isolates the Neutral and grounds from POCO , and the gen? Am I thinking backwards?
#3.... This is a Modified Square D load center with the manual transfer retainers and lockout, for backfed breakers... May I use the main lugs to power an additional small subpanel...?
Thanks guys.. This is why I keep coming back here...If I depended on my electrician, I;d be broke or fried by now.
Old 07-12-07, 08:32 AM
I
Received 43 Votes on 41 Posts
Yes.
Nothing; the neutral and ground remain interconnected with the POCO and house grounding system. Only the hots are isolated.
If the main lugs are correctly controlled by the interlock, yes. The sub-subpanel feeder conductors must match the subpanel main breaker.
