smoke detector- firex G-6
i have a firex G-6 hard wired ionization smoke detector and 2 nights ago, it went off. there was no fire. I disconnected it and I think i need to replace it since it is 15 years old. Any ideas for a replacement? I don't have a CO detector in the house as of yet. thanks
I recommend a combination CO2 detector and photoelectric smoke detector.
Whatever you do, do NOT buy an ionization only type smoke alarm. Ionization (only) type smoke detectors are almost useless in most fires in a house. Whatever you buy for a smoe detector, make sure that it has photoelectric sensors.
DON'T get the one that you can test with your TV remote. It picks up stray signals too often when you try to change a channel. Ask me how I know.
I had to wind up getting one of each in order to NOT get that feature.
I think the NFPA and the local fire marshall would take issue with that position. The majority of the alarms sold for residential use are ionization, of course because they are less expensive. And either type will alarm if a rip roaring blaze breaks out. The fire departments quote very impressive statisitics about how these alarms save lives, regardless of which type. There is a place for BOTH types in your home, because each responds in a different way and responds more quickly to different types of fires. That is why it is valuable to have both types, or combos. Just like I always use some line powered, and some battery only. I feel that covers the bases.
NFPA I believe also recommends that alarms be blanket replaced at 10 years due to a falloff in reliability with age, so the homeowner on this post should follow that advice. Someone also pointed out that with interconnected alarms, there is always a question mark between brands, and even within brands, a newer one should not be connected with older ones since the interconnect voltage may very well be different.
I assure you, I know what I am talking about. Refer to the web site www.aquariumtest.com to see why ionization type smoke detectors are the wrong type to have, if you ony have one type.
With an ionization (only) type detector, you will be dead long before the rip roaring fire breaks out.
support of Racraft
Check into MA.
We are looking at not allowing IONs' in residential use.
Supported by The fire marshall.
Most certainly get a co detector.
