Wire cooktop and hood with same cable?
Old 07-19-07, 03:06 PM
Question Wire cooktop and hood with same cable?
My gas cooktop manufacturer requires a dedicated 15 amp circuit, and the exhaust hood requires an individual 15 or 20 amp circuit(2 wire with ground). Can these circuits share the same 14/3 cable? i.e. two separate hots, shared neutral and shared ground. Would I install a separate junction box for each appliance?
Old 07-19-07, 03:09 PM
Yes, these can be on a multi-wire circuit. But I would recommend a 20 amp multi-wire circuit, not a 15 amp one. Somebody some day will want to install a microwave hood, which will be better served with a 20 amp circuit.
The hood will likely need to be hard wired. I am not familiar with cook top units, but I believe that they can be either way. Regardless, you end up with two connections, at separate places.
Old 07-19-07, 05:28 PM
Thank you.
Thanks, good point about a future microwave.
