Electric boiler hookup
Old 07-20-07, 12:41 PM
I'm looking at getting an electric boiler, and am wondering if I need to upgrade my electrical service to do this. The boiler I need uses 125 amps, and my service is only 200 amps. Is this going to be an issue? Can I just get a 125 amp breaker, and hook it up, or is there more to it? Thanks for any info.
Old 07-20-07, 12:49 PM
You probably need a service upgrade to supply anything as large as 125 amps. Are you sure this number is accurate?
The only way to be sure, however, is to do a load calculation.
Old 07-20-07, 12:53 PM
Unless your 200A service is vastly oversized, probably. You will need to do (or have an electrician) do a demand load calculation to determine if your current electrical service has enough remaining capacity to support the boiler.
There's probably more to it. These usually have a few heat stages. It's likely that the boiler requires three 40A circuits or some configuration like that. I would be surprised if it requires a single 125A circuit.
