120v fuse for my amplifier
Old 07-26-07, 02:31 PM
i need a 4 amp 120v fuse 50-60 hz and i cant seem to find one anywhere. is there another fuse i can use say a 125 volt or something. can someone please help me i am very frustrated?
Old 07-26-07, 02:35 PM
You can use a fuse which is rated 110, 115, 120, 125V; these all mean the same thing in North American wiring.
Old 07-26-07, 02:55 PM
Yes, it has to be four amps. Check electronic repair shops. This is the type of item they would have in stock and probably be willing to sell pretty cheap.
does it have to be 4 amps
Old 07-26-07, 03:28 PM
the only one i can find that is 4 amps 250v the person i talked to said it would work but im not so sure
Old 07-26-07, 07:25 PM
Rollie73's Avatar
Any fuse that is rated to safely carry 250 volts can be used in a 120 volt circuit as long as it will fit in the fuseholder. The 250 volt rating means that the fuse cansafely handle up to 250 volts. The fuse is an overcurrent device, meaning it is made to protect against too many amps.
This fuse should work just fine for you.
