Main Lug
Old 08-02-07, 06:59 PM
Cool Main Lug
I have a General Electric cat no. TM1410 model-1 breaker box with a 100 amp main breaker. Can the just the main breaker be change from a 100 amp to a 200 amp breaker, I have six open slots that can be used
Old 08-02-07, 07:26 PM
nap's Avatar
nap
nap is offline
New Member
Doubtful. The panel is rated for 100 amps and that is the largest breaker you can put in as a main. If it would be possible to put in a larger main, you would have to have documentation from GE stating that that specific panel was built with 200 amp rated buss and it is acceptable to install a 200 amp main.
Chances are it would be cheaper and easier in the long run to simply put in a new 200 amp panel.
You would also have to upsize the feeder wires and your service feeders as well as your meter to do this anyway.
Old 08-02-07, 07:39 PM
pcboss's Avatar
Depending on how you plan on using the 6 open slots you may not need to change the main breaker.
If you have questions about the capacity of your service you should do a load calculation.
Old 08-02-07, 08:21 PM
HotxxxxxxxOKC's Avatar
Sounds like he might be adding up each of his existing breakers and that is at 100 or more, which we all know doesn't matter.
