Adding a switch to garage lights
Received 0 Votes
Hi,
I have 3 lights in my garage controlled by a single switch. The wiring goes from the switch box to the first light in the center of the garage. From there, two wires run to two more lights. How would I add a switch so the first switch controls two of the lights and the second switch controls one light. I have access to the attic space above the garage and can get to all the wires. My house is 10 yrs old. I'm guessing this is pretty simple, but some detailed instructions would be much appreciated. Thanks.
Second Light
First Light---------------Switch
Third Light
Second Light
Third Light
Received 0 Votes
Replace the cable from the witch to the first light with with three conductor cable (plus ground).
Add the second switch, use the red wire for the second switched hot, make the changes at the first light.
