home emergency generator
Old 08-06-07, 10:58 AM
mil
mil is offline
Hi, I have read most of the threads about connecting an emergency generator. My question is how do I check if my Wen Power generator neutral is floating or bonded? My transfer switch calls for a floating neutral. I called the customer help line with no luck. Thanks
Old 08-06-07, 11:25 AM
With the generator off, use an ohmmeter or multimeter to check for continuity between the ground pin and neutral pin of the generator receptacle. No continuity = floating; continuity = bonded.
Old 08-06-07, 05:41 PM
mil
mil is offline
Thanks ibpooks, looks like I am good to go.
