Installing a light
Old 08-06-07, 01:27 PM
Installing a light
Aparantly I didn't pay close enough attention when I took down my bathroom light fixture. I am trying to put up a new light fixture.
There are three large wires coming into the fixture. One is from the electrical box , one goes to the light switch, and one goes to the bathroom plug. I drew a picture of it:
http://smg.photobucket.com/albums/v508/CdnSee/?action=view&current=electrical.jpg
I need to figure out how to install this light fixture now.... There are two bulbs on the fixture.
I don't know if this is important but before I Before I took the old light off and disconnected all the wires *DUH* the plug worked even when the light switch wasn't on.
Old 08-06-07, 02:15 PM
Received 42 Votes on 40 Posts
If you encounter any red wires, stop and post back. Otherwise, wirenut the following groups together:
All bare grounds, including light fixture ground if it has one.
Neutrals: white wire from power, white wire to receptacle, white wire to light fixture.
Hots: black wire from power, black wire to receptacle, white wire to switch.
Switched hot: black wire from switch, black wire from light fixture.
Old 08-06-07, 08:00 PM
Thanks
Thanks for the reply.... Just to make sure I don't screw it up I wanted to check that the receptecle is the plug?
Old 08-06-07, 09:08 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No a plug isn't a receptacle but what you are calling a plug is a actually a receptacle. <G> (And I grew up calling them outlets which the pros here would take issue with also so we all learn.)
Old 08-07-07, 08:25 AM
Yep. If you'd like to know the technical terms, a plug is on the end of a cord (also called a cord cap). A plug goes into a receptacle. A light bulb screws into a socket, and one or more sockets together in a housing makes up a luminaire (light fixture). Any point where electricity is used, such as a luminaire, receptacle or hard-wired appliance, is called an outlet. Most of the time everyone knows what you mean, but sometimes the terms are needed for precision and clarity.
Old 08-07-07, 08:55 AM
Awesome
THANK YOU SO MUCH!
I will let you know how it goes..... Right now I have to patch the hole I made in the wall to move where the fixture would be.
