flood light blinks on and off
Old 08-15-07, 08:43 AM
My flood light will stay on for a while then blink off and come on again.
all connection on the light are secure. Could this be a ground connection issue? The light is new. Help please
Old 08-15-07, 08:45 AM
Is it switched? Have you checked connections there?
Old 08-15-07, 08:46 AM
I suspect that it is either heat or a motion sensor issue. Are you using the right size bulbs? Is there a motion sensor?
Old 08-15-07, 09:47 AM
Temporarily switch the bulb to a 40-watt bulb. If it stops doing it, then it's a heat issue.
Old 08-15-07, 11:28 AM
Andrew's Avatar
You do not provide much information as to where this floodlight is used. If it is an outdoor fixture, is there a photocell? Be sure light from the bulbs are not shining into the cell, as this will fool it into thinking it is daytime, thus turning the lights off. The lights will then turn back on, and so on....
Old 08-15-07, 03:49 PM
Rollie73's Avatar
Sounds like a thermally protected light fixture. Downsize the bulb and see what happens. How long does this light stay on before it goes out? Is there a photocell or motion detector? Give us more info so we can give you more accurate advice.
