14Hole ground kit
Old 08-15-07, 08:06 AM
Question 14Hole ground kit
I have a GE 200A main panel, and I want to add an additional 14Hold ground kit. How do I determine which model (TGL2P, TGL20CP, TGL4P, or TGK12CP) is appropriate for my panel?
Thanks.
Old 08-15-07, 08:24 AM
Take a look at the panel specifications sheet on the load center cover...it should tell you the ones that fit the panel. If that isn't readable then you probably can call an electrical supply house and get that information. The tgk12cp is a 12 hole ground bar most likely but remember you can double up grounds of the same size per hole so possibly a smaller capacity ground bar would work for you. Try the ge website if all else fails.
Roger
Old 08-17-07, 07:33 AM
Thumbs up Thanks Roger
Roger
You were correct, it said I could use the TGL2 or 4. Thanks for the heads-up.
John
