Does NM need to be stapled within 12" of service panel?
Old 08-15-07, 01:53 PM
JoeTheZombie's Avatar
I've read that an NM cable must be stapled within 12" of a metal box, or within 8" of a plastic box. Does this apply to the service panel? Because I do not have enough room to staple down 35 circuits within 12".
Old 08-15-07, 02:24 PM
pcboss's Avatar
You are correct.
Some staples are listed for use with 2 cables. You could also use the stak-its that allow more cables to be secured.
Old 08-15-07, 02:38 PM
I'm thinking about nailing in a 2x4 on it's side above the panel to provide a 3.5" surface across the joist space to staple. Is this how it is typically done?
Also, what about in the wall where I have replaced K&T? I'm not going to tear the wall apart to fit in a staple...
Old 08-15-07, 02:47 PM
Speedy Petey's Avatar
"I'm thinking about nailing in a 2x4 on it's side above the panel to provide a 3.5" surface across the joist space to staple. Is this how it is typically done?"
That's exactly what I do.
"Also, what about in the wall where I have replaced K&T? I'm not going to tear the wall apart to fit in a staple..."
Fished cables do not have to be stapled.
Old 08-15-07, 02:49 PM
pcboss's Avatar
If you have fished the cables into a finished wall cavity there is an exception that relieves you of the need to staple in the wall.
