How high should I place a Sub Panel above ground
We are running a 50 amp service to a sub panel for a mobile home. We are using an outdoor above gorund sub panel. How high above ground should the panel be?
D
D
the highest breaker in the most upward position cannot be higher than 6' 6". Other than that, there isn;t really any requirement. Depending on the panel size I typically mount mine at 6' to the top of the panel.
That makes things pretty much eye level for the average person.
