Panel Question
Old 08-31-07, 07:30 PM
Panel Question
Has anyone worked with a Murray 200amp MBP ? LC4040B1200P
40 Space panel.
I'm going to be swapping out my existing panel with this one and since my current panel has only one ground/neutral bar and the new one has 2 i was wondering how in this new panel do i bond the 2 together?
It has a strap that runs from the ground bar under the main bus and over to the neutral bar on the other side. but there is no physical connection. There is a solid copper lug that is attached to the strap near the neutral bar that if you loosen can be placed into the adjacent hole on the neutral bar and tightend. Is this all that is done.
If anyone knows anything about this panel and can tell me would be greatly appreciated. Thanks in advance. John
Old 08-31-07, 07:47 PM
If the two can be connected as you describe, then you must do that. The panel also comes with a GREEN screw that MUST be installed.
This is threaded thru the neutral bus into a threaded hole in the panel.
This is the only panel after the meter correct? whith only 3 wires going to it and 1 ground to a rod and the water pipe correct? If so, thats the way.
Old 08-31-07, 10:32 PM
Does your panel look like this...... cut and paste
http://www.murrayconnect.com/docs/0706/MYSA-MRSLC-0403.pdf
Roger
Old 09-02-07, 05:53 PM
Didn't come with a screw that's why I was wondering. Yes it is the only panel after the meter and three wires but only wire to the water pipe, no ground rod yet. Will be putting 2 in during this panel install.
Old 09-02-07, 05:58 PM
Roger
Yes but with 40 spaces.
Old 09-02-07, 06:42 PM
John, looks like your OK.
The strap from the neutral to groun d bus is the bond between the two.
The strap from the bus must be bonded (screwed to the can (metal enclosure)
The grounds and neutrals will connect to the 2 busses.
To confirm,Use a continuity tester. both of these busses should have continuity with each other and the enclosure.
Old 09-03-07, 07:00 AM
Ok I'll check it with my fluke.
Old 09-21-07, 09:57 AM
It's official
Just completed my 200 amp service upgrade/panel swap
Everythings good to go. The last step for me was to bug the new cable at the weatherhead and pull the new cable to panel from the old meter pan and put it into the new one.
I kinda had to do it in two stages, I completed the panel swap last week and did the overhead this morning.
Called the POCO and they will come out monday and put on a new security tag on the meter.
I have to say though that I've been working with/around power for about 17 years and honestly I would never do a upgrade myself again. what a pain in the rear. I def have a new found respect for guys that do them everyday. That 4/0 is a ***** to work with.
Well my next phase is installing the sub in my garage so till then..........
Oh yeah thanks everyone for your help.
Old 09-21-07, 10:04 AM
Oh yeah I think I'll post some pics when I get a chance.
Old 09-21-07, 10:39 AM
4/0 is easy compared to 500kcm.
Old 09-21-07, 08:33 PM
lol, i'll bet. better yet I don't wanna know lol
