How do you connect different color phone wires?
Old 09-06-07, 11:55 PM
R
I recently ran some 6 conductor phone cable through the house, but couldnt finish the job because I ran out of cable. I need to connect the the new cable I bought to the cable I was already running, but the colours are different. What colours go to what wire?
1st cable:
white - red - blue - black - green - orange
2nd cable:
green - green/white - blue - blue/white - orange - orange/white
Thank you
Old 09-07-07, 01:30 AM
R
Received 1 Vote on 1 Post
This page shows the various standards: http://nemesis.lonestar.org/reference/telecom/cables/25pair.html
You're original wiring (the solid colors) is under "Insulation Solid Color Code" (list #2).
The new wiring is under "Insulation Band-Marked Color Code" (list #1).
Basically match up the numbers to the respective colors:
Red = White/Blue
Green = Blue/White
Black = White/Orange
Yellow = Orange/White
Blue = White/Green
Orange = Green/White
The first color listed is the primary color of the wire, the secondary color is the band or mark (white/blue is mainly white with small blue marks).
Where are you going to splice these together? It would be a good idea to either do it in a junction box at the last jack you could reach or at a mini patch panel. Just in case you have a problem, it's nice to know where to find the ends of the cables.
Old 09-07-07, 08:37 AM
F
let me add one more comment as above what he did gave the correct colour pairs
the old colours red / green is line 1 ,, Black/ Yellow is line two ,, bleu / Orange is line 3
those most common colour pairs and please make sure you have it on correct sequnece when you hook up to the phone jack[s]
for two line phone jack the middle two is line one and outer two is line two like this 2,1,1,2 if you look at the jack you will see why i say that this is most common way ditto with 3 line as well but for 4 lines that get tricky i will leave this part out for now due there is 2 or 3 diffrent way to do this
Merci, Marc
Old 09-07-07, 09:22 AM
mango man's Avatar
but only one correct way
Old 09-07-07, 05:56 PM
5
"back in the day" the polarity of connection to the telephone ( tip and ring terminals) mattered. Today, although you should try to be consistent, the phone equipment does not care.
