Reload this Page >
12' distance between outlets - true distance or wall distance?
Old 09-07-07, 02:57 PM
C
So, I have two outlets that are 12' apart if you measured directly between them. However, they are on different walls, and if you measured along the wall, the distance is further than 12'.
If I'm adding outlets to the room anyway, should I add one here? I don't need one here but I don't want the electrical to not follow code.
Thanks,
Chris
Old 09-07-07, 03:29 PM
I
The distance is measured along the base of the wall.
Old 09-07-07, 04:08 PM
Speedy Petey's Avatar
And you'd be surprised how broad the definition of wall is.
For instance, the fixed portion of a sliding glass door is wall space. As is a railing, such as in the case of a balcony.
