3-way switch with pwr from junction box
Old 09-08-07, 05:52 AM
K
How do I wire the 3-way switch with the power source in the junction box? There is only 1 wire (14/3) going to the switch. THere's a red, black, and white, and ground wire. On the 3-way dimmer is 2 red, and a black, and a green. Do i connect black to black, red to red and the other red to white wire?
Old 09-08-07, 06:45 AM
pgtek's Avatar
Received 1 Vote on 1 Post
hi
on your dimmer switch is there one wire with a tag call common????????
on the other 3 way switch check witch wire is connected to the common screw, connect the same to the way switch
Old 09-08-07, 07:09 AM
Received 201 Votes on 178 Posts
WE need a better description of what you have. Look here see if you can find your setup.
http://www.selfhelpandmore.com/switchoutlet/3way/index.htm
Old 09-08-07, 09:43 AM
P
IF this 3-wire cable connects the box with the 2-wire "Feed-In" cable (the box where the dimmer connects) to the box where the other 3WS is located, then consider the White wire to be a "Red" wire, so the 2 Red leads on the dimmer connect as you asked.
