Weather sealing conduit?
Old 09-14-07, 05:16 PM
Unclediezel's Avatar
What do you guys use to weather seal LB boxes, For moisture and Temperature transfer from outdoors to indoors?
Big box had no clue, and the local supplier told me "SPRAY FOAM"?????
Old 09-14-07, 05:28 PM
I will not use the spray foam because some of them can eat the insluation on the cables [ i did see it happend before ] but normally most sparkys used sorta of used like clay putty which the GB [ GarnderBender ] will have it in big box store not all of them will stock this item [ this putty is non drying type so it is the best to use this for this kind of appacation
Merci, Marc
dont get a funny idea with silcone caulk they are almost impossible to pull it out when the cables go bad i allready done few of them so far
Old 09-14-07, 06:02 PM
DUCT SEAL- Trade term. This as stated remains plyable. STAY away from the spray foam.
LBs', you can buy a gasket for them.
Old 09-14-07, 06:06 PM
Rollie73's Avatar
Silicone is not a great idea as Marc says. Spray foam is an absolute NO, NO.
Look for a product called "Duct Seal". It is , as Marc suggests, a non drying ,non hardening grey colored putty, which will help prevent air or water penetration and can be easily removed if you ever need to change out the wires.
