Electric for refrigerator in basement
Old 09-15-07, 11:10 AM
R
I'm in the process of finishing our basement. It's dry and is new construction. I'm going to be putting in a small refrigerator in a bar area. What should I use for the outlet? GFCI? Other? thanks.
Old 09-15-07, 11:21 AM
L
Plane ole' rec is fine. Small bar fridge a 15A 914 g wire) ckt is pleanty.
If room for only 1 ckt in the area go ith a 20A (12 g wire)
Old 09-15-07, 11:37 AM
No GFCI.
Dick
Old 09-15-07, 11:48 AM
R
Thanks! Should I use GFCI's for the rest of the room? Also, can I put the fridge, lights, and outlets (for tv, dvd, etc.) on same 15A circuit?
Old 09-15-07, 12:02 PM
L
GfI by the sink only. If possible, Lights and fridge should be fine on 15A. The entertainment stuff, I would put those on it's on 20A ckt. If you have room for 2 ckts.
If not go with 1 20A.
Old 09-15-07, 12:12 PM
R
I think I can extend the existing 15A for the lights to the fridge. Then add a 20A for GFCIs for entertainment stuff and work area. Does this work, and 12/2 or 14/2 wire for 20A?
thanks again.
Old 09-15-07, 12:19 PM
L
12/2 for 20A- 14/2 15A
If this area is a finished space no (code) need for GFCI.
