Reload this Page >
I put on a ceiling light with fan in my room, fan working but not light why?
Old 09-19-07, 10:41 AM
Why is my room light not working? I change the bulb, bought a new light pls help
Old 09-19-07, 10:46 AM
204icecream's Avatar
did u properly connect all the wires? to which ones goes where? plese try and explain exactly what u did.
thanks, icecream
Old 09-19-07, 11:02 AM
Start at the beginning. What happened? What did you do that caused this (if anything)?
Be prepared that you might very well have to investigate and fix this. If that makes you feel uncomfortable, then you may want to call an electrician.
Old 09-19-07, 10:44 PM
ray2047's Avatar
Did you have a black and blue wire at the fan? Did you connect both to the black power wire.
Note: Blue is usually the color for the light hot but it could be different. Check your instructions.
