Sub Panel Finally!
Old 10-01-07, 09:39 PM
Sub Panel Finally!
Well it's that time. I finally get to install my sub in the garage (attached).
Main panel is 200 amp. Planning on installing 100 amp double pole breaker in it and running 2-2-2-4 ser al cable to sub panel which happens to be old mainpanel. I have to install a ground bar in this panel as it never had one.
Anyone see a problem with this configuration?
Cable will be within structure for the entire run.
Old 10-01-07, 10:07 PM
Yes the grounding bar must be installed and also make sure the bonding screw/ band must be removed from the netrual bussbar but i am hope you are saying the SER this is for indoor useage cant run this outdoor at all
Merci, Marc
Old 10-02-07, 07:05 AM
Merci, Marc
I think the cabel is service entry rated (round) it will be indoors the whole run is this ok?
Old 10-02-07, 09:03 AM
Received 42 Votes on 40 Posts
Yes, SER is okay indoors. Be sure to use no-ox grease on the aluminum terminations.
Old 10-02-07, 10:38 AM
Thanks will do.
