Why single outlet receptacle for sump pump?
Old 10-06-07, 07:14 PM
Finishing basement and was going to put sump pump on new circuit. The pump was plugged into single outlet receptacle and it's the same in another house that I saw, recently built. It's currently on a 15A circuit with little load, not GFCI. I had to ask because it's not in my Stanley "Complete" Wiring book. Thanks in advance.
James
Old 10-06-07, 08:10 PM
nap's Avatar
nap
nap is offline
New Member
the single allows the exception to the use of GFCI protection.
GFCI's tend to not like motors so it prevents nuisance tripping of a GFCI.
Old 10-07-07, 05:09 AM
A single receptacle also prevents someone else from adding a load to the circuit.
Old 10-07-07, 11:35 AM
If you replace the receptacle with a single-pole switch you will eliminate the possibility that someone may use the receptacle for a cord-connected drop-lite or power tool , neither one properly Grounded.
