Clearance between gas and electrical
Old 10-08-07, 04:43 PM
Arrow Clearance between gas and electrical
Sorry to keep asking stupid questions!
Anyone know how much clearance I need from a gas valve to an electrical outlet (behind a range) ?
Thanks again!
Old 10-08-07, 05:23 PM
Speedy Petey's Avatar
No clearance is required.
Old 10-08-07, 06:31 PM
Keep asking !!
Thanks again!
There is only one "stupid" question I have ever heard...
Thats the one never asked!
Stupid ideas and comments....... Another issue.
Old 10-10-07, 08:25 PM
Call a local inspector
Gas lines and electrical lines near each other is not always a good thing.... call a local inspector as they should be able to answer your questions at no charge.
Old 10-11-07, 04:07 AM
Why is that...?
Old 10-11-07, 07:35 AM
Once you put enough space between them so that you can operate the valve and use the receptacle without bumping into the other, you'll have plenty of space. Gas valves are only a problem if they leak, and if they do, you'll be dead from the gas before the nearby electrical outlet causes any trouble.
Old 10-11-07, 12:54 PM
EXACTLY my point.
