wiring thermostat
Old 10-12-07, 11:16 AM
Question wiring thermostat
I'm trying to install a new thermostat, but my brain fart due to not eating caused me to unhook the existing one without marking the wires. Does anyone know what wires may go to where. I have a Blue, Yellow, Red, and Green. My possible connections according to the instructions are Rh=heat pwr supply, Rc=cool pwr supply, W=Heat signal, Y=cool signal, and G=Fan. There's a prexisting jumper from Rh to Rc on the new thermostat. It's a Honeywell RTH230B.
If I wanted to use a multi-meter, what would I be looking for?
Any help would be appreciated, thanks!
Rob
Old 10-12-07, 11:30 AM
The blue wire is strange, thermostat wire is usually white, red, green, yellow. What type of heating equipment do you have? Do you have an air conditioner?
In the typical case:
red = power supply
yellow = cool signal
white = heat signal
green = fan signal
Old 10-12-07, 11:37 AM
Why not try looking at the other end of the wires, at the furnace, and see where they are connected.
Old 10-12-07, 11:41 AM
Most thermostat cable i useally know they come in 2 ,4 ,5 and 7 but very rarely 9 conductors
i will list the most common colours
Red
White
Yellow
Green
Bleu
Orange
Red/white stripe
Purple
sometime may have other colour combo as well if not in the list but it do crop up once a while
Normally the Red is power supply [ typically 24 volts ac ]
yellow for cooling
white heat
green fan
the additonal color will used on heat pump or muti stage units[ it will varies a bit but i will post the most common ]
orange for back up heat
bleu second stage [ both heating and cooling stage]
but keep in your mind some HVAC may wired with diffrent set up my best bet is check the control panel on the furance or air handler unit
that will useally give you a head up how it ran
Merci, Marc
