220 to 110 splitter
Old 10-12-07, 11:55 AM
220 to 110 splitter
Hello,
I am wondering if this is possible and if so, how it can be accomplished.
I would like to construct a splitter that would would take a 220 volt outlet and split it into two independent 110 volt circuits.
Thanks for any help.
Old 10-12-07, 12:00 PM
F
It depending on how big you want to make the splitter is
but basic rules here to do that in proper way the exsting 240 volt repectale must have 4 wire repectale set up to get this working right but if have 3 wire set up you cant because the netrual and ground is tied together on 3 wire set up and that part that is a no no.
once you tell me what the 240 volt repecteale you have like dryer or range type or other size then i can able guide the correct way how to do this in safe manner
Merci , Marc
Old 10-12-07, 12:25 PM
R
Start at the beginning. What are you trying to do? Is this temporary? Permanent?
